[OpenLayers-Users] Problems with layer order
Andreas Hocevar ahocevar at opengeo.org
Tue Mar 15 20:04:17 EDT 2011
OpenLayers only groups vector layers into one svg root when you use a SelectFeature control with multiple layers and have it activated. Otherwise, each layer has its html div and its own svg root.
Cheers,
Andreas.
On Mar 10, 2011, at 10:24 , Kempi wrote:
> Hello...
> I'am new with openlayers and could make a lot of things. But one thing is
> strange and I don't understand it:
> If I add my vector layers they are normally all in one svg image. Each layer
> has its own g-tag. Thats nice... but if it is so the function on the layer
> setZIndex dosen't have any effect. This is logical because the z-index match
> on the hole svg-image.
> Question 1:
> But how can i change the g-tags order in the image if I like to change that
> after the initiation process?
> Question 2:
> If I add a layer after a while, openlayers put them into a separated svg
> image. Thats nice because than I can work with z-indexes but the div of that
> new svg is greater then the visible part of the svg image. That is the
> reason why I can't work with mouseover events on the svg image under the new
> svg image I made. How dose the openlayerscript decide when it makes a new
> svg image and do I have the posibility to affect the behavior of OpenLayers?
> I would be glad to get some help with these questions.
> regards
> Kempi
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-layer-order-tp6158137p6158137.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
