[OpenLayers-Users] What would you use?
Jan Martin
janmartin at diy-streetview.org
Mon Mar 21 06:10:46 EDT 2011
Hi all,
I need to switch to a back-end that scales.
Please suggest what technology to use.
This is my custom front-end using open layers and the custom written flash
DIY streetview player.
http://www.diy-streetview.org/data/development/20110217/index.html
For then map data is provided like this by a text-file:
A single data set looks like this:
lat lon imgdirection filename nation country town street
49.9942724285861 8.66443542324444 339 000037.jpg Germany
Hessen Langen Westendstrasse
For the DIY streetview player:
Each pano (e.g. "000045") has a corresponding xml file e.g. "000045.xml".
(File location can be changed in the DIY streetview player to point to the
same URL for all streetviews.)
Describing both the "pano" istself, and "neighbour"s to be displayed.
<?xml version="1.0" encoding="utf-8"?>
<eyesisplayer>
<pano direction="88" latitude="49.9945861297528"
longitude="8.66527973166667" altitude="188.9559633" />
<neighbours>
<neighbour path="000044.xml" latitude="49.99458200"
longitude="8.66510383" altitude="189.84849720" />
<neighbour path="000046.xml" latitude="49.99459026"
longitude="8.66545564" altitude="188.06342780" />
<neighbour path="000088.xml" latitude="49.99463573"
longitude="8.66556697" altitude="173.86521180" />
<neighbour path="000087.xml" latitude="49.99451248"
longitude="8.66556220" altitude="173.76674110" />
<neighbour path="000043.xml" latitude="49.99457787"
longitude="8.66492792" altitude="190.74103240" />
<neighbour path="000047.xml" latitude="49.99459439"
longitude="8.66563155" altitude="187.17089200" />
<neighbour path="000089.xml" latitude="49.99475898"
longitude="8.66557174" altitude="173.96368040" />
<neighbour path="000086.xml" latitude="49.99438923"
longitude="8.66555743" altitude="173.66826920" />
</neighbours>
</eyesisplayer>
Obviously the map approach does not scale at all, and the .xml files are
hard to maintain at best.
What would you use to provide this data?
Thanks,
Jan
http://www.DIY-streetview.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110321/ceb68a69/attachment.html
