[OpenLayers-Users] Re: problem with overview map
Christian Mayer mayer at terrestris.de
Thu Mar 24 04:03:09 EDT 2011
I am not quite sure what the problem is.
Here is some working code from me, maybe you try this:
     var options_ovmap = {
         mapOptions: {
             projection: map.getProjection(),
             maxExtent: map.getMaxExtent(),
             numZoomLevels: 1
         layers: [ov_ovmap] // PUT HERE A VALID AND VISIBLE LAYER
     var overviewMap = new OpenLayers.Control.OverviewMap(options_ovmap);
     overviewMap.div = document.getElementById("overviewMapDiv"); // REPLACE HERE YOUR DIV
Best Regards,
Chris
Am 23.03.2011 23:16, schrieb vrbikdan:
> Hi,
> no, I set it correctly, 'cause longitude in the Czech Republic is around 15°
> and lattitude around 50°, so no, this is set correctly.
> Dan
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-with-overview-map-tp6190056p6202139.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
