[OpenLayers-Users] getFeatureInfo doesn't work correctly
vrbikdan
vrbikdan at gmail.com
Fri Mar 25 04:58:22 EDT 2011
Hi all,
I have a little problem with getFeatureInfo. I have several point layers at
GeoServer and I need see information on click on some point. I tried to
modify code in Layer Preview but if I click, it writes "No QUERY_LAYERS has
been requested, or no queriable layer in the request anyways". In Layer
Preview is everything ok, but in my map doesn't. Do you anyone some ideas,
what I should do with it?? Part of my code is below.
Thanks, Dan
body5 = new OpenLayers.Layer.WMS("nádraží a infocentra",
"http://localhost:8080/geoserver/wms",
{width: '462',
layers: 'dp:body5',
styles: '',
srs: 'EPSG:900913',
height: '512',
format: 'image/png',
tiled: 'true',
tilesOrigin : map.maxExtent.left + ',' +
map.maxExtent.bottom,
transparent: 'true'
{minScale: 60000, maxScale: 10000}
map.events.register('click', map, function (e) {
document.getElementById('infoDiv').innerHTML =
"Loading... please wait...";
var params = {
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
FEATURE_COUNT: 50,
Styles: '',
WIDTH: map.size.w,
HEIGHT: map.size.h,
format: 'text/html'};
OpenLayers.loadURL("http://localhost:8080/geoserver/wms", params, this,
setHTML, setHTML);
OpenLayers.Event.stop(e);
function setHTML(response){
response.responseText;
View this message in context: http://osgeo-org.1803224.n2.nabble.com/getFeatureInfo-doesn-t-work-correctly-tp6206993p6206993.html
