[OpenLayers-Users] mapObject is null using ve?
Andreas Hocevar
ahocevar at opengeo.org
Tue May 3 11:07:35 EDT 2011
Did you include the Bing API script in your HTML document, as shown in
http://openlayers.org/dev/examples/bing.html?
Other than that, I'd recommend signing up for an API key and using
OpenLayers.Layer.Bing. Layer.Bing doesn't need an external mapObject -
it is just tiles like any other layer that inherits from
OpenLayers.Layer.XYZ.
Andreas.
On Tue, May 3, 2011 at 4:19 PM, ulao <S_K_U_N_X at yahoo.com> wrote:
> For some reason ve now gives me errors? I use this
> VEAerial = new OpenLayers.Layer.VirtualEarth( "Virtual Earth Raods",
> {'type': VEMapStyle.Road ,'sphericalMercator': true , 'maxExtent': new
> OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34)} );
> then when adding the base layer I get mapObject is null. I tried to use the
> .Bing constructor and use the example given, I get object expected. I do
> not have a VE key, its this an issues all of a sudden?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/mapObject-is-null-using-ve-tp6327434p6327434.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
