[OpenLayers-Users] WFS reprojection on Google Maps
Charles Galpin
cgalpin at lhsw.com
Wed May 4 09:51:01 EDT 2011
Hi Luis
I remember having trouble getting this right when I first started using openlayers. Once I figured it out, I kept using the same basic setup so I don't remember the details, but this is what I use for my map options. Perhaps give them a try.
var options = {
// the "community" epsg code for spherical mercator
projection: "EPSG:900913",
displayProjection: new OpenLayers.Projection("EPSG:4326"),
// map horizontal units are meters
units: "m",
// this resolution displays the globe in one 256x256 pixel tile
maxResolution: 78271.51695,
// these are the bounds of the globe in sperical mercator
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
20037508, 20037508)
hth
charles
On May 4, 2011, at 5:51 AM, Luís de Sousa wrote:
> Dear all,
> I've been trying to reproject WFS layers on Google Maps without
> success. After reading several threads here and elsewhere it became
> apparent that WFS 1.1.0 takes care of reprojections by itself, without any
> processing needed client side. Hence I tried simply to reproject the
> Tazmania shapes from Geoserver on a Google Maps base layer; while the
> WFS layers are indeed there, they do not seem to have been reprojected:
> http://www.flickr.com/photos/46630302@N04/5686739802/in/set-72157626519940667/
> Below goes the code, note that I'm using a local version of Geoserver
> on port 8090. I'd thank if anyone could hint at what I'm missing.
> Thanks,
> Luís
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <style type="text/css">
> #map {
> width: 560px;
> height: 460px;
> border: 1px solid black;
> </style>
> <script src="http://localhost:8090/geoserver/www/OpenLayers-2.9/OpenLayers.js"
> type="text/javascript"></script>
> <!-- Google API-->
> <script src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
> <script defer="defer" type="text/javascript">
> function init(){
> var map = new OpenLayers.Map("map", {
> projection: new OpenLayers.Projection("EPSG:900913")
> var gphy = new OpenLayers.Layer.Google(
> "Google Physical",
> {type: G_PHYSICAL_MAP}
> var roads = new OpenLayers.Layer.WFS(
> "Roads",
> "http://localhost:8090/geoserver/wfs",
> {typename: 'topp:tasmania_roads'},
> typename: 'tasmania_roads',
> featureNS: 'http://www.openplans.org/topp',
> extractAttributes: false,
> version: "1.1.0",
> srsName: "EPSG:900913"
> roads.style = OpenLayers.Util.applyDefaults(
> {strokeWidth: 2, strokeColor: "#ff0000"},
> OpenLayers.Feature.Vector.style["default"]);
> var states = new OpenLayers.Layer.WFS(
> "States",
> {typename: 'topp:tasmania_state_boundaries'},
> typename: 'tasmania_state_boundaries',
> version: "1.1.0",
> states.style = OpenLayers.Util.applyDefaults(
> {strokeWidth: 3, strokeColor: "#333333"},
> map.addLayers([gphy, roads, states]);
> map.addControl(new OpenLayers.Control.Navigation());
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.setCenter(new OpenLayers.LonLat(147, -42), 7);
> </script>
> </head>
> <body onload="init()">
> <h5>This is a reprojection test on Google Maps.</h5>
> <div id="map"> </div>
> </body>
> </html>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
