[OpenLayers-Users] WFS reprojection on Google Maps
Andreas Hocevar
ahocevar at opengeo.org
Thu May 5 12:13:01 EDT 2011
2011/5/5 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Thank you Andreas, it worked like a charm.
> There is one issue though, everytime I pan or zoom into the map I get
> this annoying "Map Data" dialogue about Google's copyright. Anyway to
> deal away with that?
If you're using OpenLayers 2.10, you have to replace
http://maps.google.com/maps/api/js?v=3.3&sensor=false
with
http://maps.google.com/maps/api/js?v=3.2&sensor=false
in the script resources.
Andreas.
> Thank you,
> Luís
> 2011/5/5 Andreas Hocevar <ahocevar at opengeo.org>:
>> Hey,
>> OpenLayers.Layer.WFS is depracated. See
>> http://openlayers.org/dev/examples/wfs-protocol-transactions.html for
>> an example of how to overlay WFS layers properly on a Web Mercator
>> map.
>> Note, however, that the main issue in your code is not the fact that
>> you are using OpenLayers.Layer.WFS (it seems like it is configured
>> properly), but missing map configuration parameters (units,
>> maxResolution, maxExtent). You either have to set them manually, or
>> use GMaps v3 instead of v2, because OpenLayers.Layer.Google v3 base
>> layers have these settings configured already. See
>> http://openlayers.org/dev/examples/google-v3.html for an example on
>> how to use v3.
>> Also note that as soon as you work with Web Mercator maps, you cannot
>> specify coordinates in longitude/latitude. If you do so, you need to
>> transform them, which is also shown in the google-v3 example I linked
>> above.
>> Regards,
>> Andreas.
>> 2011/5/4 Luís de Sousa <luis.a.de.sousa at gmail.com>:
>>> Dear all,
>>> I've been trying to reproject WFS layers on Google Maps without
>>> success. After reading several threads here and elsewhere it became
>>> apparent that WFS 1.1.0 takes care of reprojections by itself, without any
>>> processing needed client side. Hence I tried simply to reproject the
>>> Tazmania shapes from Geoserver on a Google Maps base layer; while the
>>> WFS layers are indeed there, they do not seem to have been reprojected:
>>> http://www.flickr.com/photos/46630302@N04/5686739802/in/set-72157626519940667/
>>> Below goes the code, note that I'm using a local version of Geoserver
>>> on port 8090. I'd thank if anyone could hint at what I'm missing.
>>> Thanks,
>>> Luís
>>> <html xmlns="http://www.w3.org/1999/xhtml">
>>> <head>
>>> <style type="text/css">
>>> #map {
>>> width: 560px;
>>> height: 460px;
>>> border: 1px solid black;
>>> </style>
>>> <script src="http://localhost:8090/geoserver/www/OpenLayers-2.9/OpenLayers.js"
>>> type="text/javascript"></script>
>>> <!-- Google API-->
>>> <script src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
>>> <script defer="defer" type="text/javascript">
>>> function init(){
>>> var map = new OpenLayers.Map("map", {
>>> projection: new OpenLayers.Projection("EPSG:900913")
>>> var gphy = new OpenLayers.Layer.Google(
>>> "Google Physical",
>>> {type: G_PHYSICAL_MAP}
>>> var roads = new OpenLayers.Layer.WFS(
>>> "Roads",
>>> "http://localhost:8090/geoserver/wfs",
>>> {typename: 'topp:tasmania_roads'},
>>> typename: 'tasmania_roads',
>>> featureNS: 'http://www.openplans.org/topp',
>>> extractAttributes: false,
>>> version: "1.1.0",
>>> srsName: "EPSG:900913"
>>> roads.style = OpenLayers.Util.applyDefaults(
>>> {strokeWidth: 2, strokeColor: "#ff0000"},
>>> OpenLayers.Feature.Vector.style["default"]);
>>> var states = new OpenLayers.Layer.WFS(
>>> "States",
>>> {typename: 'topp:tasmania_state_boundaries'},
>>> typename: 'tasmania_state_boundaries',
>>> version: "1.1.0",
>>> states.style = OpenLayers.Util.applyDefaults(
>>> {strokeWidth: 3, strokeColor: "#333333"},
>>> map.addLayers([gphy, roads, states]);
>>> map.addControl(new OpenLayers.Control.Navigation());
>>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>>> map.setCenter(new OpenLayers.LonLat(147, -42), 7);
>>> </script>
>>> </head>
>>> <body onload="init()">
>>> <h5>This is a reprojection test on Google Maps.</h5>
>>> <div id="map"> </div>
>>> </body>
>>> </html>
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
Andreas Hocevar
