[OpenLayers-Users] The correct approach to using only Spherical
Mercator projection maps
Janis Elmeris
janis.elmeris at intelligentsystems.lv
Sat May 7 09:25:24 EDT 2011
Hello!
I am using an OpenLayers map with OpenStreetMap and Google map base
layers. Currently I've get it working by setting map's projection to
EPSG:900913, map's display projection to EPSG:4326, setting an option
sphericalMercator=true for Google maps layer's and transforming
OpenLayer.LonLat and OpenLayer.Geometry.Point from EPSG:4326 to
EPSG:900913 every time I add one to the map. I've picked this up from
various examples, so I'm not sure if this is the right approach in my
situation. Is it?
If it is the right approach, I have several questions.
1) Why should I set sphericalMercator=true for Google maps, but not for
OpenStreetMap? Can the Google maps layers be also used with the option
being false, and can OSM be used with the option true?
2) What's the point of setting the map's projection to EPSG:900913 and
map's display projection to EPSG:4326, if I still have to transform the
coordinates every time my script interacts with the map (adding objects
on specific coordinates)?
3) Do I need the transformation at all, if I use only maps with the
Spherical Mercator projection (Google maps and OSM are all supposed to
be using Spherical Mercator)? Shouldn't everything already be in that
projection?
Thank you!
Janis
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110507/2d7bd6b9/attachment.html
