AW: [OpenLayers-Users] Get Feature Info in pop up from geoserver
Sukuchha Shrestha
sukuchha at yahoo.de
Mon May 9 05:13:29 EDT 2011
Hi Ivan,
This thing is making me mad. I have spent more than two days on this things
still its not working. My display projection is mercator but my WMS layer from
where i want to get info is in espg:4326.
I am trying this in two ways:
1)
info = new OpenLayers.Control.WMSGetFeatureInfo({
url: 'http://geoweb.hft-stuttgart.de:80/geoserver/wms',
title: 'Identify features by clicking',
layers: [wmslayer],
//hover:true,
queryVisible: true,
eventListeners: {
getfeatureinfo: function(event) {
map.addPopup(new OpenLayers.Popup.FramedCloud(
"chicken",
map.getLonLatFromPixel(event.xy),
null,
event.text,
null,
true
//alert(event.text);
map.addControl(info);
info.activate();
There are point feautures in my WMS. WMS is congfigured in ESPG:4326 in my
geoserver. When i click to a point, the point information is passed
in projectionMercator or projection4326 ? I think this is where the problem lies
! To work correctly the point information should be passed in ESPG: 4326 but i
dont see a parameter in OpenLayers.Control.WMSGetFeatureInfo where i can set
this . I always get blank reponse !
2) Geoserver way.
map.events.register('click', map, function (e) {
//document.getElementById('nodelist').innerHTML =
"Loading... please wait...";
var params = {
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX:
map.getExtent().transform(map.getProjectionObject(),projection4326).toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: 'test_postgis:addressv2b',
FEATURE_COUNT: 50,
Layers: 'test_postgis:addressv2b',
Styles: '',
WIDTH: map.size.w,
HEIGHT: map.size.h,
format: 'image/jpeg'};
OpenLayers.loadURL("http://geoweb.hft-stuttgart.de:80/geoserver/wms", params,
this, setHTML, setHTML);
//OpenLayers.Event.stop(e);
// sets the HTML provided into the nodelist element
function setHTML(response){
"chicken",
null,
response.responseText,
null,
true
response.responseText;
But this ones says, "event is not defined ".
Please help me with this
sukuchha
Von: Ivan Grcic <ivan.grcic at geo-solutions.it>
An: Sukuchha Shrestha <sukuchha at yahoo.de>; geoserver-users
<geoserver-users at lists.sourceforge.net>
Gesendet: Freitag, den 6. Mai 2011, 19:12:50 Uhr
Betreff: Re: [OpenLayers-Users] Get Feature Info in pop up from geoserver
it seems that for some reason you are not getting any features back
from you geoserver. (are you sure there are some features at requested
point?)
This can also happen due to several things, but most likely your layer
is not configured with correct spatial reference system, so geoserver
doesnt return any feature at requested point.
Cheers,
Ivan
On Fri, May 6, 2011 at 5:59 PM, Sukuchha Shrestha <sukuchha at yahoo.de> wrote:
> Hello ivan,
> Thank you very much for pointing me towards the righ path. I tried to apply
> as shown in that html but but i ran into the problem again.
> Somehow my pop is not returning the get feature info but empty. I tried to
> see with firebug and i found that the geoserver is actually returning
> something.
> <html>
> <head>
> <title>Geoserver GetFeatureInfo output</title>
> </head>
> <style type="text/css">
> table.featureInfo, table.featureInfo td, table.featureInfo th {
> border:1px solid #ddd;
> border-collapse:collapse;
> margin:0;
> padding:0;
> font-size: 90%;
> padding:.2em .1em;
> padding:.2em .2em;
> font-weight:bold;
> background:#eee;
> table.featureInfo td{
> background:#fff;
> table.featureInfo tr.odd td{
> background:#eee;
> table.featureInfo caption{
> text-align:left;
> font-size:100%;
> font-weight:bold;
> text-transform:uppercase;
> padding:.2em .2em;
> </style>
> <body>
> </body>
> </html>
> I guess this is header template that is there is geoserver. Ideally it
> should come with content templete as well.
> Any idea what is the problem here.
> Thanks
> Sukuchha
> CC: users at openlayers.org
> Gesendet: Freitag, den 6. Mai 2011, 11:02:29 Uhr
> Hi Sukuchha,
> You should use openlayers popup feature.
> This example is perfect for you :
> http://openlayers.org/dev/examples/getfeatureinfo-popup.html
> Regards,
> Ivan
> On Fri, May 6, 2011 at 10:49 AM, Sukuchha Shrestha <sukuchha at yahoo.de>
> wrote:
>> Hello nice people,
>> i am trying to display get feature info of WMS layers coming from my
>> geoserver. I do not have much experience with open layers and geoserver as
>> well.
>> This is what geoserver preview layers give to me:
>> // support GetFeatureInfo
>> var params = {
>> BBOX: map.getExtent().toBBOX(),
>> X: e.xy.x,
>> Y: e.xy.y,
>> QUERY_LAYERS: map.layers[0].params.LAYERS,
>> FEATURE_COUNT: 50,
>> Layers: 'sf:bugsites',
>> Styles: '',
>> WIDTH: map.size.w,
>> HEIGHT: map.size.h,
>> format: format};
>> OpenLayers.loadURL("http://localhost:8080/geoserver/wms", params, this,
>> setHTML, setHTML);
>> But in my case, I want to display the getfeatureinfo not in a external div
>> but on a openlayers right beside the where user have clicked. If, any one
>> could provide me a working code to do this and explain in a coincise
>> manner
>> Sorry if this is too basic stuff for some people ! I am in class 1 of
>> openlayers and geoserver :))
>> Sukuchha
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Ivan Grcic
> GeoSolutions S.A.S.
> Software Engineer
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 962313
> http://www.geo-solutions.it
> http://geo-solutions.blogspot.com/
> http://twitter.com/geosolutions_it
> http://www.youtube.com/user/GeoSolutionsIT
Ivan Grcic
GeoSolutions S.A.S.
Software Engineer
Italy
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110509/7775e743/attachment-0001.html
