[OpenLayers-Users] Re: [OpenLayers-Dev] OpenLayers and GeoCouch
Karl Guillotte
karl.guillotte.1 at gmail.com
Mon May 9 10:59:12 EDT 2011
Yep! OpenLayers is working like a charm with CouchDB, not tested yet with
GeoCouch. GeoCouch is really promising!
My reference on the web is Max Ogden @ http://www.maxogden.com/ and his work
@ http://pdxapi.com/ > you find there a lot of information.
Good luck
Karl
2011/5/9 Dipl. Inf. Carsten Eider <eider at fh-bingen.de>
> Maybe this may help you a bit: http://vmx.cx/cgi-bin/blog/index.cgi
> Am 09.05.2011 14:45, schrieb Andrew Larcombe:
> > On 09/05/2011 10:36, Dipl. Inf. Carsten Eider wrote:
> >> Hi folks,
> >> has anyone ever heard of geocouch(https://github.com/couchbase/geocouch
> >> or even developed an application with openlayers based on it?
> >> TIA Carsten
> > Yes - it's an extension to couchdb, a document-oriented data store
> > that's accessed over http. Am looking to build something in it this
> > week as it happens - would also be interested to hear from people with
> > experience in this space.
> > Andrew
> Mit freundlichen Grüßen / Yours faithfully
> Carsten Eider
> Dipl. Inf. (FH)
> Kompetenzzentrum für Innovative Informationssysteme
> c/o Fachhochschule Bingen / University of applied sciences Bingen
> Berlinstraße 109
> 55411 Bingen
> Tel: +49 (0) 6721 / 409-179
> Fax: +49 (0) 6721 / 994-251
> email: eider at fh-bingen.de
> Internet: iis.fh-bingen.de
> Diese E-Mail, inklusive anhängender Dateien, kann vertrauliche und/oder
> rechtlich geschützte Inhalte enthalten.
> Wenn Sie nicht der richtige Adressat sind und diese E-Mail irrtümlich
> erhalten haben, benachrichtigen Sie bitte sofort den Absender und vernichten
> Sie sodann die Originalnachricht.
> Die unbefugte Kopie, Weiterleitung oder sonstige Verbreitung dieser
> Nachricht ist nicht gestattet.
> This e-mail, including attachments, may contain confidential and/or
> privileged information.
> If you are not the intended recipient, please notify the sender immediately
> then delete the original message.
> Any copying forwarding and/or distribution without permission of the sender
> is forbidden.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110509/987c3b25/attachment.html
