[OpenLayers-Users] Re: Overlaying WMS layers on Google Maps
BMcBride
bmcbride at opengeo.org
Wed May 11 10:13:09 EDT 2011
Louis,
First, you have to pass your map options to the map constructor after the
div:
map = new OpenLayers.Map('map', options);
Also- it's not necessary to use proj4js when you are working with EPSG:4326
and EPSG:900913, openlayers can handle these natively.
Try:
var options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
20037508, 20037508)
Bryan McBride, GISP
OpenGeo - http://opengeo.org
Expert service straight from the developers.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Overlaying-WMS-layers-on-Google-Maps-tp6351168p6352008.html
