[OpenLayers-Users] Layerswitcher question
Alex
zeitalex at googlemail.com
Fri May 13 03:58:59 EDT 2011
you should work with layer's event "visibilitychanged"
layer1.events.register("visibilitychanged", layer1, function() {
if (this.getVisibility()) {
layer2.setVisibility(false);
layer2.events.register("visibilitychanged", layer2, function() {
layer1.setVisibility(false);
Am 13.05.2011 09:36, schrieb Boer, dr. W.M. de (Thijs):
> Hello list members,
> In an OL application I would like to switch 1 layer on and at the same time, switch another layer off (in the layerswitcher panel).
> Both layers are overlays. So the on/off of these two layers in the layerswitcher are connected as it were.
> Is this possible and if so, has anyone a bit of code for it ?
> Kind regards
> Thijs de Boer
> GIS Competence Center
> Dienst Landelijk Gebied
> Postbus 20021 | 3502 LA | Utrecht
> F 030 275 69 99
> M 06 52 40 10 69
> w.m.dboer at minlnv.nl
> Dit bericht kan informatie bevatten die niet voor u is bestemd. Indien u
> niet de geadresseerde bent of dit bericht abusievelijk aan u is gezonden,
> wordt u verzocht dat aan de afzender te melden en het bericht te
> verwijderen.
> De Staat aanvaardt geen aansprakelijkheid voor schade, van welke aard
> ook, die verband houdt met risico's verbonden aan het elektronisch
> verzenden van berichten.
> This message may contain information that is not intended for you. If you
> are not the addressee or if this message was sent to you by mistake, you
> are requested to inform the sender and delete the message.
> The State accepts no liability for damage of any kind resulting from the
> risks inherent in the electronic transmission of messages.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
