[OpenLayers-Users] Expanded OverviewMap by default
Vidal, Antoni
antoni.vidal at icc.cat
Mon May 16 03:00:50 EDT 2011
I didn’t mentioned that I’m working with GeoExt. Your solution didn’t works.
My code:
// overviewmap
var overviewMapSize = new OpenLayers.Size(128, 123);
var bounds = new OpenLayers.Bounds(258000,4485000,536000,4752000);
var genericMapOptions = {projection: "EPSG:23031", units: 'm', maxExtent: bounds}
var reference = new OpenLayers.Layer.Image(
"Overview", "./app/img/mapa_ref.jpg", bounds, overviewMapSize
var overviewOptions = {
maximized: true,
mapOptions: genericMapOptions,
layers: [reference]
var ovControl = new OpenLayers.Control.OverviewMap(overviewOptions);
Thanks
Toni.
De: Meine Toonen [mailto:meinetoonen at b3partners.nl]
Enviat: viernes, 13 de mayo de 2011 13:57
Per a: Vidal, Antoni; openlayers-users at lists.osgeo.org
Tema: Re: [OpenLayers-Users] Expanded OverviewMap by default
Hi Antoni,
Yes this is possible through the maximized option, which you can pass to the overviewmap:
var controlOptions = {
maximized: true,
layers: [...]
var overview2 = new OpenLayers.Control.OverviewMap(controlOptions);
Also take a look at the documentation:
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Control/OverviewMap-js.html
Met vriendelijke groet,
Meine Toonen
B3Partners BV
Tel: 030 214 2081
From: Vidal, Antoni [mailto:antoni.vidal at icc.cat]
To: openlayers-users at lists.osgeo.org
Sent: Fri, 13 May 2011 11:47:20 +0200
Subject: [OpenLayers-Users] Expanded OverviewMap by default
Hello list,
Is possible to get OverViewMap control expanded by default when aplication initialices?
Thank’s in advance.
Antoni Vidal
Unitat d'Aplicacions SIG-WEB
Institut Cartogràfic de Catalunya <http://mercuri.icc.cat/website/mob_nf/mob1/mob2/inici2.htm?CONSULTA=Institut%20Cartogr%25E0fic%20de%20Catalunya&XYADDRESS=429486:4580392>
Parc de Montjuïc, E-08038 Barcelona
Tel. (+34) 93 567 15 00 (ext. 3228)
www.icc.cat <http://www.icc.cat/>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110516/f717a1fb/attachment.html
