[OpenLayers-Users] WFS layer data extend ans loading strategies
Favre, Sebastien
Sebastien.Favre at spotimage.fr
Tue May 17 09:38:26 EDT 2011
Hello to all,
I'm trying to use function getDataExtent() on a WFS layer object.
The function works well when the loading strategy of the layer is FIXED.
When loading strategy is BBOX, function returns NULL.
Does someone has a solution to know max extent of the layer objects using a BBOX loading strategy ?
Thank you.
Sebastien
Ce courrier ?lectronique et toutes les pi?ces ?ventuellement jointes qu?il contient sont CONFIDENTIELS et destin?s exclusivement ? l?usage de leur destinataire. Si une erreur de transmission ou une adresse erron?e a mal dirig?e ce courrier, merci d?en informer l?exp?diteur en lui faisant une r?ponse par courrier ?lectronique d?s r?ception. Si vous n??tes pas le destinataire de ce courrier, vous ne devez pas l?utiliser, le conserver, en faire ?tat, le distribuer, le copier, l?imprimer ou en r?v?ler le contenu ? une tierce partie.
Ce courrier ?lectronique est ? usage strictement informatif et ne saurait engager de quelque mani?re que ce soit SPOT IMAGE SA, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind SPOT IMAGE SA in any contract or obligation, nor its subsidiaries.
