AW: [OpenLayers-Users] OpenLayers.Feature.style
vs.OpenLayers.Layer.Vector.styleMap
Arnd Wippermann
arnd.wippermann at web.de
Wed May 18 16:15:46 EDT 2011
i'm not sure, but if you add a style to a feature instead a styleMap to the
layer, you can't add a select style.
But there is a property selectStyle for the SelectFeatureControl.
It should also work, when the features have there own style.
//ctrlSelectFeature = new OpenLayers.Control.SelectFeature(...)
var selectStyle = OpenLayers.Feature.Vector.style['select'];
ctrlSelectFeature.selectStyle = selectStyle;
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Gissur
Þórhallsson
Gesendet: Mittwoch, 18. Mai 2011 19:13
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] OpenLayers.Feature.style
Hi guys,
I've got a vector layer that I initialize with the following code:
var vector_style = new OpenLayers.StyleMap(OpenLayers.Util.applyDefaults({
strokeColor:'yellow',
fillOpacity:0.0,
strokeOpacity:1,
strokeWidth: 2,
fillOpacity:0.1 },
OpenLayers.Feature.Vector.style["default"]));
vectorLayer.styleMap = vector_style;
This renders fine, I get yellow vector features that turn blue when I hover
over them (per default)
The problem is that later on I have an event that styles each feature
depending on a certain condition, the event is something like the following:
var feats =map.layers[22].features;
var lengd = feats.length;
cursize = 2;
for(var i=lengd-1 ;i>=0 ;i--)
if(feats[i+1]!==undefined)
if(feats[i].geometry.intersects(feats[i+1].geometry))
cursize++;
else
cursize = 2;
feats[i].style = OpenLayers.Util.applyDefaults(
graphicZIndex : (lengd-i)+1000,
strokeColor : "#"+genHex(),
fillOpacity : 0.03,
pointRadius : 7*(cursize)
OpenLayers.Feature.Vector.style["select"]);
The code above loops through the features array (these are all Points), and
if it finds features adjacent to each other in the array which also
intersect/share the same location - it draws them in bigger and bigger
increments.
The code works fine, except for the fact that I lose the select behavior
from before (the points don't turn blue when I hover over them).
Firebug reveals that the style object that I assign to the features contain
hoverStrokeColor, hoverFillColor etc, but these don't seem to do anything.
Does anybody have ideas?
Kind regards from Iceland,
Gissur
Gissur Þórhallsson
Loftmyndir ehf.
Laugavegur 13
IS 101 Reykjavík - Iceland
sími (tel): (+354) 540 2500
tölvupóstur (email): gissur at loftmyndir.is
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110518/8d9a9b70/attachment.html
