[OpenLayers-Users] Dateline WMS & vector drawing issue
Phil Scadden
p.scadden at gns.cri.nz
Thu May 19 17:43:48 EDT 2011
Welcome to the world of endless frustration. Who would have thought that
in the 21st century, programmers were still living on a flat earth. Back
engineering to fix this flat earth philosophy is a mega hassle and you
must be careful not to break use of mapping on non-earth applications,
ha ha. However...
> first problem:
> The measuring (and drawing) over the dateline does not work. There was
> an issue about exactly the same problem last august on the dev-List with
> an attached kind of "patch", but that one does not work properly
> (http://lists.osgeo.org/pipermail/openlayers-dev/2010-August/006360.html)
> and causes funny behavings.
I think I have more code patched in similar ways than are in that
patches, however there are other tricks that you need too.
Assuming you have put in ALL the patches associated with that ticket
2782, http://trac.osgeo.org/openlayers/ticket/2787, then your
measureControl should also look like:
measureDistanceControl = new OpenLayers.Control.Measure(
OpenLayers.Handler.Path, {
persist: true,
geodesic: true,
handlerOptions: {
layerOptions:
{styleMap: drawStyleMap},
citeCompliant :false
measureDistanceControl.events.on({
"measure": processMeasurements,
"measurepartial":
processMeasurements
measureAreaControl = new OpenLayers.Control.Measure(
OpenLayers.Handler.Polygon, {
persist: true,
geodesic:true,
handlerOptions: {
layerOptions:
measureAreaControl.events.on({
"measurepartial": processMeasurements
ie note geodesic= true, citeCompliant=false. In fact, make sure you have
these set for any of your path handlers (eg whatever you use in
DrawFeature).
If this still isnt working, then contact me, as I may have more patches.
Note also that these patches havent made it to 2.11, - I simply havent
had the time to learn the test environment and make tests.
> Also the WMS-layers are not drawn over the dateline. We worked with the
> "wrap dateline" parameter, but using this requires tiling and tiling
> causes much more requests and images to be loaded by the client. We have
> about 30-40 WMS in the application. A tiling will slow down the
> application (especially the client) and at least lets crash slow
> browsers like IE8 (indeed - IE9 is a lot faster).
I havent really figured out what wrapdateline is supposed to do but
mostly it turns maps into wierdness with vector layers repeated out of
place. The biggest problem however seems to be having a wms server that
understands the dateline. Geoserver 2.1 and a patched version of
geoserver 2.02 are supposed to. I havent got 2.1 up yet but the patch
only sort of worked with a great deal of odd behaviour around polygons
that cross the dateline (depending on native projection) and tiles that
cut in and out depending on whether dateline is to east or west of your
screen midpoint. I'm not convinced yet that this isnt an openlayers bug.
I even requested quote from geosolutions for fixing bug in geoserver but
they have been very slow coming back.
We had decided to defer this issue till geoserver 2.1 came out and then
work out precisely where blame lies and try and fix it ourselves. We are
in process of getting geoserver 2.1 up (glacial IT processes not
helping). Other WMS servers dont seem better. We've been screaming at
ESRI about 180 line since oh about ArcInfo version 4 (when we became
customers). Some things work but google projection isnt one of them at
least in 9.2. The last comment we had from them implied that since web
mercator didnt have envelopes, it would never work on 180 line. At the
point we dropped it and moved to geoserver which offered some hope and
we could get the source.
The very best of luck and I am ready to help in any way I can. Feel free
to email direct.
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
