[OpenLayers-Users] Re: Get Features from a WMS Layer
IvanBell
Ivan.Bell at CCA.com
Mon May 23 21:47:41 EDT 2011
I see. Can you elaborate just a little? I have seen this frequently (i.e.,
the vector being created from "featureType" and "featureNS"); but no good
explanations for how to use it.
As a newbie, the OpenLayers documentation is often ambiguous, at best. As
with this example, a lot of things are documented for an experienced reader
(as a reference) and not for a newbie (like me).
Let us say that I have the following:
- map/workspace:
workspace namespace URI: http://localhost:8081/MyMap
- stores (vector data sources):
DataSourceName: MyLayer
URL: file:data/MyMap/MyLayer.shp
- layers:
What would this WFS query look like? I tried the following (but it did not
work):
var wfs = new OpenLayers.Layer.Vector( "MyFeatures", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
url: "http://localhost:8081//geoserver/wfs",
featureType: "MyLayer",
featureNS: "http://localhost:8081/MyMap"
var features = wfs.features;
alert( features.length );
The features always returns 0 length. I have tried some different
permutations; but, I am not sure what the "featureNS" (feature namespace) is
supposed to be. I mean, the workspace namespace is not right. Am I to
assume it is supposed to be some URL for the store? If so, what might that
be? Also, I don't know what the "featureType" is.
The definitions for each (in the API doc) are as follows:
featureType
{Array(String) or String} The local (without prefix) feature typeName(s).
featureNS
{String} The feature namespace. Must be set in the options at
construction.
But neither are specific/explicit enough for me to figure it out and I have
not seen a documented example of this that allows me to glean the necessary
details.
Is there something that I am supposed to do for a WMS layer that I am not
seeing? I am using GeoServer; but there is not a WMS versus WFS
configuration for these shapefiles. At least, I have not found anything.
My problem lies with my ignorance on how to call WFS.
Thanks again for your help and prompt response.
Up the Irons!!!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Get-Features-from-a-WMS-Layer-tp6396039p6396948.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110523/15fdbb31/attachment.html
