[OpenLayers-Users] page resize breaks map?
jrom jerome.gasperi at gmail.com
Mon May 30 04:45:58 EDT 2011
I quickly look at your code.
Apparently you do not specify a height/width for your map container.
Perhaps you should try to force these values with something in pixels.
It's a nasty solution but you should give it a try to see if it works
Jerome
On Mon, May 30, 2011 at 10:19 AM, S2 <s2.akira at tin.it> wrote:
> Hi Jerome,
> thanks for taking the time to answer.
> I tried
> line 541 of
> http://s2.31337.it/
> elm.data('olmap').updateSize();
> but it seems to have no effect.
> On 30.05.2011 9.52, jrom wrote:
>> Hi,
>> Perhaps you should try a map.updateSize() after content gets loaded.
>> It will force a map repaint
>> Jerome
>> On Mon, May 30, 2011 at 9:17 AM, S2<s2.akira at tin.it>  wrote:
>>> hello all!
>>> on http://s2.31337.it/ i have some openlayers maps. the page uses ∞
>>> scroll,
>>> so that when the user scrolls to the bottom of the page, older posts are
>>> loaded automatically.
>>> when this happens the map breaks (the pictures in the map get somehow
>>> resized to a wrong size). you can try this yourself simply by scrolling
>>> to
>>> the bottom of the page, let the js load some more posts, and then scroll
>>> back up.
>>> can i somehow force the map to repaint itself? (i could do that when new
>>> content gets loaded).
>>> i tested this with ff4 and ie 8.
>>> thanks.
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
http://jrom.info
