[OpenLayers-Users] Label mis-align with IE9
Frank Broniewski
brfr at metrico.lu
Tue May 31 10:10:06 EDT 2011
Hi Andreas,
I just took
http://openlayers.org/dev/examples/vector-features-with-text.html and
added the doctype:
<!DOCTYPE HTML>
<html xmlns="http://www.w3.org/1999/xhtml">
and in the JS I added a console
renderer = (renderer) ? [renderer] :
OpenLayers.Layer.Vector.prototype.renderers;
console.log(renderer);
but I uploaded an example at
http://www.gis-hosting.lu/static/tmp/doctype.html
I'm testing with IE9 32bit Mode on Windows 7 Professional 64bit, if
that's of any importance.
All line breaks are removed from the text and the label align of the
name: toto age: 20 label is still too high in IE9. The line breaks are
also in all other browsers (Opera, Firefox, Safari and Chrome) missing.
Many thanks
Frank
Am 31.05.2011 09:33, schrieb Andreas Hocevar:
> Hi,
> the issues you describe sound like there is something weird going on
> in your application code. If you can provide a simplified example that
> shows the issue, I'll give it a look.
> Andreas.
> On Tue, May 31, 2011 at 9:02 AM, Frank Broniewski<brfr at metrico.lu> wrote:
>> Hi Andreas,
>> thanks for your reply. I tried the same example, downloaded the HTML, added
>> the HTML5 doctype (<!DOCTYPE HTML>), and tested in IE9. But still, the name:
>> toto, age: 20 point label is still not cm - aligned - it's too high. I
>> logged the renderer and it shows LOG: SVG,VML,Canvas - so I suppose as SVG
>> comes first it is used as renderer. And the page concerned had already a
>> HTML5 doctype ...
>> Another thing I noticed is that all line breaks are removed from the labels
>> when I use the HTML5 doctype, even in the other browsers.
>> So I fear it is not as simple as adding a doctype.
>> Frank
>> Am 30.05.2011 16:26, schrieb Andreas Hocevar:
>>> Playing with
>>> http://openlayers.org/dev/examples/vector-features-with-text.html,
>>> it seems that IE 9 does not align labes well in VML, depending on
>>> doctype and compatibility mode. To make IE9 use the SVG renderer,
>>> which will fix the issue, you have to use the<!DOCTYPE HTML> doctype.
>>> Andreas.
>>> On Mon, May 30, 2011 at 3:54 PM, Frank Broniewski<brfr at metrico.lu> wrote:
>>>> Hi all,
>>>> I noticed a problem with the label align in IE9. I have a style as
>>>> follows:
>>>> var defaultStyle = new OpenLayers.Style(
>>>> 'pointRadius' : '${radius}',
>>>> 'fillColor' : '#ff8200',
>>>> 'fillOpacity' : 1,
>>>> 'strokeColor' : '#fff',
>>>> 'strokeWidth' : 2,
>>>> 'cursor' : 'pointer',
>>>> 'label' : '${label}',
>>>> 'labelAlign' : 'cm',
>>>> 'fontColor' : 'white',
>>>> 'fontFamily' : 'sans-serif',
>>>> 'fontSize' : '12px',
>>>> 'fontWeight' : 'bold'
>>>> 'context' : {
>>>> 'radius' : function(feature) {
>>>> if (feature.attributes.count> 1) {
>>>> return 8;
>>>> } else if (feature.attributes.count == 1) {
>>>> // check for custom num_clients attribute
>>>> if (feature.cluster[0].attributes.num_clients&&
>>>> feature.cluster[0].attributes.num_clients> 1) {
>>>> return 8;
>>>> return 6;
>>>> 'label' : function(feature) {
>>>> return feature.attributes.count;
>>>> } else if (feature.cluster[0].attributes.num_clients&&
>>>> return
>>>> feature.cluster[0].attributes.num_clients;
>>>> return '';
>>>> It's a stylemap on a clustered vector layer and the label is misaligned
>>>> in
>>>> IE9, it's not in center-middle as it is with firefox or other browsers.
>>>> Is
>>>> this a known problem with IE? I suppose this is SVG related, so I really
>>>> have no clue what I can do. I'm using OL 2.10 ...
>>>> You can visit http://viaah.lu/adresse/clervaux/clervaux/streets/3/ for an
>>>> example
>>>> Many thanks
>>>> Frank
>>>> Frank BRONIEWSKI
>>>> METRICO s.à r.l.
>>>> géomètres
>>>> technologies d'information géographique
>>>> rue des Romains 36
>>>> L-5433 NIEDERDONVEN
>>>> tél.: +352 26 74 94 - 28
>>>> fax.: +352 26 74 94 99
>>>> http://www.metrico.lu
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Frank BRONIEWSKI
>> METRICO s.à r.l.
>> géomètres
>> rue des Romains 36
>> L-5433 NIEDERDONVEN
>> Users mailing list
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
rue des Romains 36
L-5433 NIEDERDONVEN
