[OpenLayers-Users] Re: Handler.Box units
Puneet Kishor
punk.kish at gmail.com
Wed Nov 2 19:06:21 EDT 2011
On Nov 2, 2011, at 5:54 PM, Robert Sanson wrote:
> Where is your bounds coming from?
Its coming from the code I gave below (pretty much the exact code I am using, lifted from the docs). See my original post.
> I would expect bounds to be in terms of your map projection. Whereas map.getLonLatFromPixel is used to convert a pixel location to a map coordinate.
Indeed, that is what I expected as well, which is why I was converting from google projection (my map display projection) to lat lng (the projection I want the coordinates in). Except, much to my surprise I discovered that bounds was returning pixels. Hence, my attempt to convert those pixels to lat lng directly, which failed as well.
> Regards,
> Robert
>>>> Puneet Kishor <punk.kish at gmail.com> 3/11/2011 11:46 a.m. >>>
> On Nov 2, 2011, at 4:37 PM, Puneet Kishor wrote:
>> I am reusing the sample code from the Handler.Box documentation
>> var control = new OpenLayers.Control();
>> OpenLayers.Util.extend(control, {
>> draw: function () {
>> // this Handler.Box will intercept the shift-mousedown
>> // before Control.MouseDefault gets to see it
>> this.box = new OpenLayers.Handler.Box(
>> control,
>> {done: this.notice},
>> {keyMask: OpenLayers.Handler.MOD_SHIFT}
>> this.box.activate();
>> notice: function (bounds) {
>> OpenLayers.Console.userError("bounds: " + bounds);
>> var bbox = bounds.transform(proj.google, proj.latlng).toBBOX();
>> OpenLayers.Console.userError("bbox: " + bbox);
> I am doing something wrong here trying to convert pixels to lat lng
> var bbox = bounds.toArray();
> var p1 = map.getLonLatFromPixel(bbox[0]);
> var str = "Lat: " + p1.lat + " (Pixel.x:" + p1.x + ") Lon: " + p1.lon + " (Pixel.y:" + p1.y + ")\n";
> alert(str);
> produces the following alert
> Lat: NaN (Pixel.x:undefined) Lon: NaN (Pixel.y:undefined)
> Puneet Kishor_______________________________________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense Hosted Security.
> www.websense.com
