[OpenLayers-Users] Re: proxy and apache
Tondo
gpktondo at gmail.com
Tue Nov 8 08:06:35 EST 2011
okay, here we go:
1.) localhost/cgi-bin/proxy.cgi
Browser:
*500 Internal Server Error*
The server encountered an internal error or misconfiguration and was unable
to complete your request.
Please contact the server administrator, admin at local.domain and inform them
of the time the error occurred, and anything you might have done that may
have caused the error.
More information about this error may be available in the server error log.
Firebug:Nothing
Apache err. log:
[Tue Nov 08 09:24:18 2011] [error] [client 127.0.0.1] Premature end of
script headers: proxy.cgi
[Tue Nov 08 09:24:18 2011] [error] [client 127.0.0.1] 'import site' failed;
use -v for traceback\r
[Tue Nov 08 09:24:18 2011] [error] [client 127.0.0.1] Traceback (most recent
call last):\r
[Tue Nov 08 09:24:18 2011] [error] [client 127.0.0.1] File
"C:/_SOFT/OSGeo4W/bin/proxy.cgi", line 12, in <module>\r
[Tue Nov 08 09:24:18 2011] [error] [client 127.0.0.1] import urllib2\r
[Tue Nov 08 09:24:18 2011] [error] [client 127.0.0.1] ImportError: No module
named urllib2\r
2.) localhost/client_using_proxy_cgi.html - attempt to load one WMS and two
WFS layers
Browser: Does open map window, loads controls, there are also WFS layers in
layer switcher, but there are no WFS layers visible on the map
Firebug:
POST
http://localhost/cgi-bin/proxy.cgi?url=http%3A%2F%2Flocalhost%3A8080%2Fgeoserver%2Fwfs
500 (Internal Server Error)
POST
Apache err. log:
[Tue Nov 08 09:26:57 2011] [error] [client 127.0.0.1] Premature end of
script headers: proxy.cgi, referer: http://localhost/dp_dev.html
[Tue Nov 08 09:26:57 2011] [error] [client 127.0.0.1] 'import site' failed;
use -v for traceback\r, referer: http://localhost/dp_dev.html
[Tue Nov 08 09:26:57 2011] [error] [client 127.0.0.1] Traceback (most recent
call last):\r, referer: http://localhost/dp_dev.html
[Tue Nov 08 09:26:57 2011] [error] [client 127.0.0.1] File
"C:/_SOFT/OSGeo4W/bin/proxy.cgi", line 12, in <module>\r, referer:
[Tue Nov 08 09:26:57 2011] [error] [client 127.0.0.1] import urllib2\r,
[Tue Nov 08 09:26:57 2011] [error] [client 127.0.0.1] ImportError: No module
named urllib2\r, referer: http://localhost/dp_dev.html
As far I understand, it's missing some kind of library urllib2 it trys to
include/import as some reference? So I was searching for it. Python.exe is
located in C:\_SOFT\OSGeo4W\bin and all pythons libs are located in other
directory C:\_SOFT\OSGeo4W\apps\python25\lib - urllib2.py. Okay let's use my
limited knowledge about this: do I need to simply copy->place urllib2.py to
some special directory or use some kind of absolute path to that file?
What about that PHP script? Any ideas how to do that?
Thank you guyz.
Tom
View this message in context: http://osgeo-org.1803224.n2.nabble.com/proxy-and-apache-tp6960380p6974203.html
