[OpenLayers-Users] Re: [Users] Extjs / sencha lisencing query
Andreas Hocevar
ahocevar at opengeo.org
Wed Nov 9 05:55:39 EST 2011
the answer is simple: if your application you build with GeoExt is GPL, you can use Ext JS under the GPL license. If your application is not, you need to buy a license from Sencha. Ext JS is OpenSource regardless.
In your case this means: if you put your application code under the GPL license, you don't need to buy a license from Sencha.
Andreas.
On Nov 9, 2011, at 07:57 , Robert Buckley wrote:
> Hi,
> I am confused!
> Is anyone able to simplify the debate regarding the question: "is Extjs 3.3 / 3.4 / 4.0 opensource"? I am in a discussion in my government department and some of the opinion that the use of ExtJS without a licence could be a legal minefield
> I have been using Extjs 3.3 with GeoExt 1.0 to make mapping applications. The Code I have written is open. The native ExtJS libraries are also open. Does this mean I can use them without buying a licence?
> If anyone can shed some light I would be most grateful,
> Yours,
> Robert
> Users mailing list
> Users at geoext.org
> http://www.geoext.org/cgi-bin/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
