[OpenLayers-Users] data extent for wms layer?
Andreas Hocevar
ahocevar at opengeo.org
Wed Nov 9 10:57:04 EST 2011
the best way to do this is to issue a GetCapabilities request, parse the response with OpenLayers.Format.WMSCapabilities, and look for the layer's bbox or llbbox in the capabilities object. An untested snippet to show you what I mean:
var myLayerName = "my_layer";
var obj = new OpenLayers.Format.WMSCapabilities().read(response.responseText);
var capability = obj.capability;
for (var i=0, len=capability.layers.length; i<len; i++) {
var layerObj = capability.layers[i];
if (layerObj.name === myLayerName) {
map.zoomToExtent(OpenLayers.Bounds.fromArray(layerObj.llbbox));
break;
Andreas.
On Nov 9, 2011, at 15:54 , Charles Galpin wrote:
> I'm drawing a blank on the best way to do this. I have a wms layer (for performance) that I'd like to zoom to the data extent for, but it looks like this is not available for a wms layer like you can for a vector layer.
> Is there a fast call I can make to get the extent only and then use this to zoom? I am using geoserver on the server side. Any suggestions would be appreciated.
> Thanks,
> charles
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
