[OpenLayers-Users] OpenLayers.Class destroy method question
Eric Lemoine
eric.lemoine at camptocamp.com
Fri Nov 11 14:34:25 EST 2011
On Fri, Nov 11, 2011 at 5:48 PM, laurentK2 <lboileau at k2geospatial.com> wrote:
> I'm developping my own classes using the "OpenLayers.Class" class. However,
> I'm wondering something regarding the destroy method.
> I created my own class that doesn't inherit from any other. That class has a
> few properties with values and initialize and destroy methods among others.
> In my destroy method, I assign null values to my properties to prevent
> memory leaks. Here's something that looks like it:
> ExampleClass = OpenLayers.Class(
> property: "defaultValue",
> initialize: function(options)
> // Do Stuff
> destroy: function()
> // Do Stuff
> this.property = null;
> CLASS_NAME: "ExampleClass"
> I assumed that calling the destroy method on an object of that class would
> clear that object's properties. However, it seems that the destroy call will
> nullify the assigned properties of the "OpenLayers.Class" object. That means
> that every new instance of the class won't have the defaultly assigned
> property.
> Example:
> var obj = new ExampleClass(); // obj will have its property to
> "defaultValue"
> obj.destroy(); // Destroy the obj instance.
> var obj2 = new ExampleClass(); // obj will have its property nullified!
I don't think that's correct. Do that in FireBug:
>>> A = OpenLayers.Class({prop: "default", initialize: function() {}, destroy: function() { this.prop = null; }});
>>> a = new A;
>>> a.prop
"default"
>>> a.destroy();
>>> a.prop
null
>>> b = new A;
>>> b.prop
"default"
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
