[OpenLayers-Users] Displaying EPSG:3021-locations on EPSG:900913
Roger Waara roger.waara at gmail.com
Wed Nov 23 04:46:06 EST 2011
In Sweden we are using RT90 (http://spatialreference.org/ref/epsg/3021/).
I’ve been working on a app that displays EPSG:3021-coords upon Google Maps
(EPSG:900913). (I got help by Erik Hazzard, the author of the book
Openalyers 2.10).
It’s almost working, but there is still one thing that’s kind of odd which
neither he nor I understand.
See Code below
<!DOCTYPE html>
<html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0,
maximum-scale=1.0, user-scalable=0">
    <meta name="apple-mobile-web-app-capable" content="yes">
        <link rel="stylesheet" href="
http://openlayers.org/dev/theme/default/style.css" type="text/css">
http://openlayers.org/dev/examples/style.css" type="text/css">
        <style>
           .olControlMousePosition {
                background:rgba(255,255,255,.9) !important;
                border:1px solid rgba(0,0,0,.4) !important;
                bottom:150px !important;
                font-size:1em !important;
                font-weight:bold !important;
                padding:2px !important;
                position:absolute !important;
                right:2px !important;
                width:100px !important;
        </style>
    </head>
    <body>
    <div id="map" style='height:500px;width:500px;'></div>
    <div id='point_display'></div>
<script src="http://openlayers.org/dev/OpenLayers.js"></script>
 <script src='proj4js.js'></script>
<script src="http://maps.googleapis.com/maps/api/js?v=3.5&amp;sensor=false
"></script>
    <script src="EPSG3021.js"></script>
    <script>
        var map = new OpenLayers.Map({
            div: "map",
            projection: new OpenLayers.Projection('EPSG:900913'),
            displayProjection: new OpenLayers.Projection('EPSG:3021')
       var google_hybrid = new OpenLayers.Layer.Google(
                "Google Hybrid",
                {sphericalMercator: true,type:
google.maps.MapTypeId.HYBRID, numZoomLevels: 22}
      var google_physical = new OpenLayers.Layer.Google(
                "Google Physical",
google.maps.MapTypeId.TERRAIN, numZoomLevels: 22}
      var google_satellite = new OpenLayers.Layer.Google(
                "Google Satellite",
google.maps.MapTypeId.SATELLITE, numZoomLevels: 22}
       var google_streets = new OpenLayers.Layer.Google(
                "Google Streets",
                {sphericalMercator: true,numZoomLevels: 22}
       var vector_layer = new OpenLayers.Layer.Vector(
            'Vector Layer',
                strategies: [new OpenLayers.Strategy.Fixed()],
                projection: new OpenLayers.Projection('EPSG:3021'),
                protocol: new OpenLayers.Protocol.HTTP({
                    url: "data_in_3021.json",
                    format: new OpenLayers.Format.GeoJSON({
        vector_layer.events.register('featureselected', this,
function(feature){
            var feature_html = '';
            var feature_copy = feature.feature.clone();
            var feature_reprojected =  feature_copy.geometry.transform(
                new OpenLayers.Projection('EPSG:3021'));
            feature_html += "Lon: " + feature_reprojected.x
                + " | Lat: " + feature_reprojected.y;
            feature_html += " | Antal: " +
feature_copy.attributes.observations_count;
            feature_html += "<br />";
            document.getElementById('point_display').innerHTML +=
feature_html;
        vector_layer.events.register('featureunselected', this,
function(feature){
            document.getElementById('point_display').innerHTML = '';
        map.addLayers([
        google_hybrid,
google_physical, google_satellite, google_streets, vector_layer
        //Controls
        var overview_map = new OpenLayers.Control.OverviewMap(
            { autoPan: true, size: new OpenLayers.Size(150,100) }
        var select_features_control = new OpenLayers.Control.SelectFeature(
            vector_layer,{
                clickout: true,
                toggle: false,
                multiple: true,
                hover: false,
                box: true
        map.addControls([
            new OpenLayers.Control.MousePosition(),
            new OpenLayers.Control.LayerSwitcher(),
            overview_map,
        overview_map.maximizeControl();
        select_features_control.activate();
        if(!map.getCenter()){
            map.setCenter(
                new OpenLayers.LonLat(1738182, 9069017),
                6);
    </script>
    </body>
</html>
The JSON-file contains:
{"type": "FeatureCollection", "features": [
                             {"type":"Feature",
    "geometry":{"type":"Point",
    "coordinates":[1710943, 7456832]},
    "properties":{"observations_count": 1 }}
This geolocation, 1710943, 7456832 is a well known roundabout in my
hometown and when the marker hits the map it’s placed some 400 m Northbound
and 200 meters Eastbound from where it should be. Looking at the map.
When I move the mouse over the actual marker it displays the correct
locations as above.
If I move the mouse to where it should be, it displays the wrong
lon-lat-coordinates.
I used to work with ARC-GIS before and this gives me thoughts about the
layers not being properly rectified to each other
I’d appreciate it a lot if somebody could give me a hint on where to look
and what to correct.
Best regards
Roger Waara
Sweden
Roger Waara
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111123/0a5bac51/attachment-0001.html
