[OpenLayers-Users] How to remove scaleline from print view
Peter Peterse
peter at peterse-uithuizen.com
Wed Nov 23 07:13:04 EST 2011
I would change the attributions in css ".olControlScaleLine" in the file
<http://maps.zgb.de/ertragspotential/resources/openlayers/theme/default/style.css>
Regards,
Peter
> Hi,
> In my application ( http://maps.zgb.de/ertragspotential/ ) I have a
> scaleline positioned bottom right in the map.
> I have a print button (top left ) which outputs the map div into a print
> window comprising of a html table.The problem is that the print window
> shows the scale text positioned top left without the scale line.
> I would either like to position the scale text with the scalebar together
> in the bottom right, or not at all. The problem is that I can´t find out
> how to reference the css which grabs the scale textbar.
> any help much appreciated.
> yours,
> Rob_______________________________________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
