[OpenLayers-Users] Error message using mapfish print
Ralph Dell RDell at CatawbaCountyNC.gov
Wed Nov 23 07:55:35 EST 2011
I believe that if you go back and fix the TMS problem you reported a few weeks ago, on the geoserver mailing list,  you will be able to then use that to fix your print problem.
Ralph Dell
From: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Robert Buckley
Sent: Wednesday, November 23, 2011 6:15 AM
To: geowebcache-users at lists.sourceforge.net; users at openlayers.org; users at mapfish.org
Subject: [OpenLayers-Users] Error message using mapfish print
I don´t know if this is a mapfish problem, an openlayers problem or a gwc problem..
When I export a map which has layers coming from gwc I always get this error in the pdf file
the gwc layers are displayed fine in openlayers.
java.io.IOException: Error (status=400) while reading the image from http://maps.zgb.de/geoserver/gwc/service/wms?
BBOX=1120223.6%2C6737442.5%2C1125190.8%2C6744216.0&HEIGHT=625&WIDTH=458&
TRANSPARENT=true&map_resolution=75&VERSION=1.1.1&FORMAT=image%2Fpng&SERVICE=WMS&
PROJECTION=EPSG%3A4326&format_options=dpi%3A75&LAYERS=zgb%3Atk50&REQUEST=GetMap&
STYLES=&SINGLETILE=true&SRS=EPSG%3A900913: Bad Request
Could anyone shed any light on this?
yours,
Rob
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111123/9f1756c2/attachment.html
