[OpenLayers-Users] Problems with userdefine Popupmarker-Class
in OL2.11
Norbert Renner
norbert.renner at gmx.de
Wed Nov 23 13:02:37 EST 2011
Hi Jan,
I had a look at xmas_test_only.html and it seems like disabling the
replacement of the OpenLayers Image.initImgDiv function in tappenbeck.js
would fix this:
OpenLayers.Tile.Image.prototype.initImgDiv = function() {
Not sure if this is needed any longer, I haven't tested the POI layer.
Cheers,
Norbert
Am 23.11.2011 12:01, schrieb Jan Tappenbeck:
> HI !
> i make several maps to show poi-informations like [1] (use OL 2.9.1).
> Now i want to change the ol-Version to 2.11 and then i have a big
> problem. the map tiles will repeat vertical and horizontal. look at [2]
> I use two special js-files popupmarker.js and tappenbeck.js - they
> should help to show the popupmarker easier -> but i am not the
> programmer of these files.
> i create simple examples in use ol211 - to search the mistake [3b] and
> in the moment of include the two js-files [2] will happen.
> because the programmer is uable to help in time so i ask the ol-world if
> there is someone who can help me for this important problem???
> regards Jan :-)
> [1] http://www.tappenbeck.net/osm/maps/deu/index.php?id=1032
> [2] http://www.tappenbeck.net/forum/openlayer/error_ol_kacheln_20111123.jpg
> [3a] the simple map without any poi-implementation
> http://www.tappenbeck.net/osm/maps/deu/xmas_test_ohne.html
> [3b] [3a]+include the two js-files
> http://www.tappenbeck.net/osm/maps/deu/xmas_test_only.html
> [3c] [3b]+add a poi layer
> http://www.tappenbeck.net/osm/maps/deu/xmas_test_mit.html
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
