[OpenLayers-Users] Re: using openlayers on mobile device
Gabriele Seitz ml-seitz at web.de
Thu Nov 24 03:55:24 EST 2011
Hi Chris,
if you open Example
"http://www.openlayers.org/dev/examples/mobile-layers.html" and use your
browser function to examine the source code, you will find a script-element
that is named like the example, e.g.  . Click it and you get the Javascript
source code for this example.
Try OpenStreetMap example. Search for "mobile" on the examples list.
I hope this helps.
Gabriele
View this message in context: http://osgeo-org.1803224.n2.nabble.com/using-openlayers-on-mobile-device-tp7026520p7027455.html
