[OpenLayers-Users] Re: use sub-zoomlevels
Andreas Hocevar
ahocevar at opengeo.org
Thu Nov 24 15:51:46 EST 2011
On Thu, Nov 24, 2011 at 7:35 PM, Jan Tappenbeck <osm at tappenbeck.net> wrote:
> Hi !
> the function is ok - but did i understand correct that openstreetmap
> (mapnik) is a cached tile - so the funktion will not work ??
If you are using a recent version of OpenLayers (from master on
github), it will work, thanks to the new client zoom feature.
Andreas.
> regards Jan :-)
> Am 19.11.2011 22:10, schrieb Eric Lemoine:
>> On Saturday, November 19, 2011, Jan Tappenbeck
>> <mailto:osm at tappenbeck.net>> wrote:
>> > hi !
>> > everybody used zoomlevels like 10,11,12,13,.....
>> > but is it possible to define / use subzoom-levels like 10.4, 11.3 ???
>> > regards Jan :-)
>> Hi
>> The map has a fractionalZoom option that you may want to look at.
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> <mailto:eric.lemoine at camptocamp.com>
>> http://www.camptocamp.com
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
