[OpenLayers-Users] registering and unregistering map events
Puneet Kishor
punk.kish at gmail.com
Mon Oct 3 19:44:43 EDT 2011
I would welcome suggestions to solve the following. I want to "enable" the "activation" of a functionality at a certain zoom level, and after the functionality is completed, I want the "deactivate" the functionality, but still keep it enable-able (huh!). See below for a better description of the problem --
// add a "zoomend" event so…
map.events.register("zoomend", map, function() {
// when the map is zoomed in at the correct level,
if (map.getZoom() > 3) {
// a button is activated so that when the button is clicked…
$("#button").bind("click", function() {
// the button is turned "on"
// the map begins listening for clicks to do
// cool functionality
map.events.register("click", map, function(e) {
coolFunctionality(e);
// but when the map zoom is not at the correct level,
else {
// map is no longer listening to clicks
map.events.unregister("click", map, function(e) {
// and the button is turned "off" and deactivated
$("#button").unbind("click", function() {});
In another part of the script
"coolFunctionality": function (e) {
// do cool functionality,
// turn the button "off" (but it can still be clicked)
// and turn off the map listener so it may not be fired accidentally
So, the problem is, when I am in `coolFunctionality()` and `unregister` the event, I am still in the zoom level range where the event is `register`ed. Hmmmm... what to do?
Puneet Kishor
