[OpenLayers-Users] Re: registering and unregistering map events
Puneet Kishor punk.kish at gmail.com
Mon Oct 3 20:48:07 EDT 2011
Seems like the problem I am encountering is that I am unable to "unregister" a "click" event from the map. Is there a way to ascertain if an event has been "unregister"ed successfully? (that is, besides, of course, discovering that it is still firing).
On Oct 3, 2011, at 6:44 PM, Puneet Kishor wrote:
> I would welcome suggestions to solve the following. I want to "enable" the "activation" of a functionality at a certain zoom level, and after the functionality is completed, I want the "deactivate" the functionality, but still keep it enable-able (huh!). See below for a better description of the problem --
>    // add a "zoomend" event so…
>    map.events.register("zoomend", map, function() {
>        // when the map is zoomed in at the correct level,
>        if (map.getZoom() > 3) {
>            // a button is activated so that when the button is clicked…
>            $("#button").bind("click", function() {
>                // the button is turned "on"
>                // the map begins listening for clicks to do
>                // cool functionality
>                map.events.register("click", map, function(e) {
>                    coolFunctionality(e);
>        // but when the map zoom is not at the correct level,
>        else {
>            // map is no longer listening to clicks
>            map.events.unregister("click", map, function(e) {
>            // and the button is turned "off" and deactivated
>            $("#button").unbind("click", function() {});
> In another part of the script
>    "coolFunctionality": function (e) {
>        // do cool functionality,
>        // turn the button "off" (but it can still be clicked)
>        // and turn off the map listener so it may not be fired accidentally
> So, the problem is, when I am in `coolFunctionality()` and `unregister` the event, I am still in the zoom level range where the event is `register`ed. Hmmmm... what to do?
> Puneet Kishor
