[OpenLayers-Users] featureadded
Puneet Kishor punk.kish at gmail.com
Fri Oct 7 14:58:56 EDT 2011
On Oct 7, 2011, at 10:09 AM, Peter Peterse wrote:
> Try the next:
>    var context={
>       az : function(feature) {
>          return feature.attributes.az;
>       rate : function(feature) {
>          return feature.attributes.rate;
>    var template = {
>       externalGraphic: "arrow.png",
>       rotation: "${az}",
>       graphicWidth:6,
>       graphicHeight: "${rate}"
>    var styleMap = new OpenLayers.StyleMap(new OpenLayers.Style(template,
> {context:context}));
>    var vectorLayer = new OpenLayers.Layer.Vector("Simple Geometry",
> {styleMap: styleMap});
>    // create a point feature
>    var points = [];
>    var p = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Point(-72, 42).transform(proj.latlng,
> proj.google));
>    p["styleMap"] = styleMap;
>    p.attributes = {};
>    p.attributes["az"] = 76;
>    p.attributes["rate"] = 33;
>    points.push(p);
> I think it should work.
Wow, it does work. Thanks a ton. And, it is supremely complicated. I still don't get why a styleMap is being assigned to the layer, only to reassign it to the point on the layer. And, what is the point of putting "bind values" in the template, but then use functions to returns values for those values. Might be helpful to understand the chain of commands in OL as each point's definition is encountered and it is rendered on the layer.
Now, I have figure out why `layer.events.on({"featureadded": function(event) {}});` is not working.
Puneet.
