[OpenLayers-Users] Panning 2.10 vs 2.11
Ricardo Bayley ricardo.bayley at gmail.com
Fri Oct 14 10:19:55 EDT 2011
Thanks, using the buffer does help !
Ricardo
2011/10/13 Eric Lemoine <eric.lemoine at camptocamp.com>
> On Thu, Oct 13, 2011 at 4:19 AM, Roald de Wit <list at rdewit.net> wrote:
> > Hi,
> > Isn't this just because OL 2.11 has changed the default buffer from 2 to
> 0?
> > Try adding 'buffer: 2' (or 1 for example) to your layer options to get
> the
> > old behaviour back. The reason that the buffer was set to 0 was to reduce
> > the amount of unnecessary tile requests (IIRC).
> Right. So buffer:2 + tileLoadingDelay:0 should should make the layer
> behave similarly as with 2.10.
> > Looking at the 2.11 release notes, there was no mention of this change,
> so I
> > added it at the end:
> > http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes
> Thank you!
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111014/05df7d12/attachment.html
