[OpenLayers-Users] the same ol' 4326/900913 stuff-up
Puneet Kishor
punk.kish at gmail.com
Sat Oct 15 17:45:41 EDT 2011
Thanks Richard. That was it.
On Oct 15, 2011, at 4:25 PM, Richard Greenwood wrote:
> On Sat, Oct 15, 2011 at 2:36 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
>> I am confounded by this basic problem, so instead of wasting any more time on it, I ask your help (at the risk it being a stupid question). My data are stored in EPSG:4326, and I am having MapServer pull it out with the following incantations
>> MAP
>> PROJECTION
>> "init=epsg:4326"
>> "init=epsg:900913"
>> END
> Only one coordinate system may defined with the PROJECTION block. It
> doesn't matter which one you define if all of your layers also have a
> PROJECTION block
>> WEB
>> METADATA
>> ows_enable_request "*"
>> wms_srs "EPSG:900913 EPSG:4326"
>> END
>> END
>> LAYER
>> NAME "lyr"
>> DATA "the_geom FROM table USING UNIQUE gid USING srid=4326"
>> PROJECTION
>> "init=epsg:4326"
>> "init=epsg:900913"
>> END
> Within the LAYER, the PROJECTION block defines the coordinate system
> that the layer is in. So only one of the above can be correct.
>> METADATA
>> END
>> I am adding the layer to my map with
>> map = new OpenLayers.Map("map", {
>> projection: new OpenLayers.Projection("EPSG:900913"),
>> displayProjection: new OpenLayers.Projection("EPSG:4326"),
>> units: "dd",
>> maxResolution: 156543.0339,
>> maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508)
>> var lyr = new OpenLayers.Layer.WMS(
>> "lyr",
>> "http://server/cgi-bin/app",
>> {layers: "lyr"},
>> {isBaseLayer: false}
>> map.addLayers([lyr]);
>> Yet, I get the following error
>> <ServiceException code="InvalidSRS">
>> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS must be valid for all requested layers.
>> </ServiceException>
>> What am I doing wrong?
>> Puneet Kishor _______________________________________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
