[OpenLayers-Users] access to object-variable-names
Jan Tappenbeck
osm at tappenbeck.net
Thu Oct 20 02:53:03 EDT 2011
Hi !
i create some layers like vlayer_1, vlayer_2, vlayer_3, ...
map.vlayer_3 = new OpenLayers.Layer.Vector("Zuglinien");
map.addLayer (map.vlayer_3);
now i want to iterate through the objects like vlayer_1, vlayer_2,
vlayer_3, ...
i use following code to get the objects with
var layerobj = map.getLayersByClass(/.*/);
alert ('len: '+layerobj.length);
the count is ok - but how get i the names?
layerobj[i].id oder layerobj[i].name is not the right - name is the name
in the layerpanel.
but how ???
2. question - how is the regex to select only objects with the name
vlayer_* ??
regards Jan :-)
