[OpenLayers-Users] map isn't appearing
moataz ahmed
moataz_a7mad at yahoo.com
Sat Oct 22 04:27:06 EDT 2011
Hii
I am trying to create a Dynamic SLD App using Geoserver + OpenLayers + Ajax
i
am trying with openlayers to read an sld file "the user will upload it
to the server" and i am sending a request with Ajax to retrieve .sld
file contents and it works fine till now.
the problem is that the map is not appearing although the sld contents retrieved in a good manner .
this is my javascript code :
<script>
function Send_Req(str){
if (str=="")
document.getElementById("map").innerHTML="";
return;
if (window.XMLHttpRequest)
{// code for IE7+, Firefox, Chrome, Opera, Safari
xmlhttp=new XMLHttpRequest();
else
{// code for IE6, IE5
xmlhttp=new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.onreadystatechange=function()
if (xmlhttp.readyState==4 && xmlhttp.status==200)
var map;
var untiled;
var tiled;
var pureCoverage = false;
OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
OpenLayers.Util.onImageLoadErrorColor = "transparent";
format = 'image/png';
if(pureCoverage) {
document.getElementById('filterType').disabled = true;
document.getElementById('filter').disabled = true;
document.getElementById('antialiasSelector').disabled = true;
document.getElementById('updateFilterButton').disabled = true;
document.getElementById('resetFilterButton').disabled = true;
document.getElementById('jpeg').selected = true;
format = "image/jpeg";
var bounds = new OpenLayers.Bounds( -142.152, -72.075,87.654, 103.162);
var options = {
controls: [],
maxExtent: bounds,
maxResolution: 0.8976796874999999,
projection: "EPSG:3273",
units: 'm'
map = new OpenLayers.Map('map', options);
var sldco=xmlhttp.responseText;
alert("sldco ="+sldco);
tiled = new OpenLayers.Layer.WMS(
"attr_based_polygon:sld_cookbook_polygon - Tiled", "http://localhost:8080/geoserver/attr_based_polygon/wms",
LAYERS: 'attr_based_polygon:sld_cookbook_polygon',
SLD_BODY: sldco,
isBaseLayer: true,
format: format,
tiled: !pureCoverage,
tilesOrigin : map.maxExtent.left + ',' + map.maxExtent.bottom
buffer: 0,
displayOutsideMaxExtent: true,
isBaseLayer: true
untiled = new OpenLayers.Layer.WMS(
"attr_based_polygon:sld_cookbook_polygon - Untiled", "http://localhost:8080/geoserver/attr_based_polygon/wms",
SLD_BODY: sldco,
format: format
{singleTile: true, ratio: 1}
map.addLayers([untiled, tiled]);
map.zoomToExtent(bounds);
xmlhttp.open("GET","http://localhost/trial9.php?q="+str,true);
xmlhttp.send();
</script>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111022/1bf1cf5a/attachment-0001.html
