[OpenLayers-Users] Weird popup behaviour in IE
JavierMR
javiersdevmail at ymail.com
Wed Oct 26 02:59:33 EDT 2011
HI,
when opening a popup it behaves different in IE than the others (Firefox,
Chrome, Opera).
The issue occurs when a popup is opened and it's heigth exceds the heigth of
the map's div. When this occurs in FF, Chrome and Opera the popup simple
adds a vertical scroll (sometimes also a horizontal one) and it's fine, but
in IE (tested on IE8) in addition to adding the vertical scroll it also
makes the width popup macth the map's div width, wich result in an enormous
popup hiding the map.
Here are two images showing the issue:
http://osgeo-org.1803224.n2.nabble.com/file/n6931713/popupFF.png
http://osgeo-org.1803224.n2.nabble.com/file/n6931713/popupIE.png
Below a incluide an html wich reproduces the issue.
<html>
<head>
</head>
<body onload="init()">
<div id="map" style="height: 300; width:100%;"></div>
<p id="status" />
</body>
</html>
Is there a fix for this? or should i open a tickect?
Best regards.
Javier Monge
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Weird-popup-behaviour-in-IE-tp6931713p6931713.html
