[OpenLayers-Users] Geowebcache in openlayers problem
Robert Buckley
robertdbuckley at yahoo.com
Thu Oct 27 08:44:57 EDT 2011
hi,
This is a follow up of my previous attempt to understand how to use geowebcache(gwc) and use openlayers to visualize data.
I have been having problems with gwc and EPSG:900913 in openlayers. I want to serve raster data over googlemaps, but cannot get geowebcache to work together with openlayers in EPSG:900913
As a test, I have set up test layer called wgs84Point which is a postgis layer with 3 points digitized in wgs84(EPSG:4326). I have fed it into geoserver and have build two clients to visualize the points. One of the clients has a map set up in wgs84 (EPSG:4326), the other identical map with Google (EPSG:900913).
http://maps.zgb.de/eeg/wgs84.html
http://maps.zgb.de/eeg/900913.html
Both maps contain the wms version of the points layer and also the geowebcache version.
As can be seen, the WGS84 EPSG:4326 version lines both the wms and geowebcache points perfectly.
from the geowebcache demo page in geoserver I can view the layer in both 900913 and 4326
here is one tile in EPSG:900913
http://maps.zgb.de/geoserver/gwc/service/wms?LAYERS=zgb%3Awgs84point&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=1164288.8146777,6946597.1295898,1169180.7844873,6951489.0993994&WIDTH=256&HEIGHT=256
and the same point is EPSG:4326
http://maps.zgb.de/geoserver/gwc/service/wms?LAYERS=zgb%3Awgs84point&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=10.532455444336,52.833938598633,10.533142089844,52.834625244141&WIDTH=256&HEIGHT=256
My Geoserver logs are giving me this...
2011-10-27 14:39:21,406 ERROR [geowebcache.GeoWebCacheDispatcher] - X,Y values for the tile index were calculated to be {1081.4697265626, 1380.0979003904074} which had to be rounded to {1081, 1380} and exceeds the threshold of 10%. Perhaps the client is using the wrong origin ? http://maps.zgb.de/geoserver/gwc/service/wms
which corresponds to the firebug output for the pink tiles..400: X,Y values for the tile index were calculated to be {1081.4697265626, 1376.0979003905672} which had to be rounded to {1081, 1376} and exceeds the threshold of 10%. Perhaps the client is using the wrong origin ?
So I really don´t know where to look for solutions.
Any help is most welcome
yours,
Rob
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111027/fe45d062/attachment.html
