AW: [OpenLayers-Users] Change vector style dynamically
Arnd Wippermann
arnd.wippermann at web.de
Thu Oct 27 17:10:43 EDT 2011
U can use a styleMap with context and set the color by attribute "routes".
function set_styleLine()
var context = {
getColor : function (ft){
if(ft.attributes.routes=="all")
return "#000000";
else
return "#FF0000";
var template = {
strokeColor: "${getColor}",
strokeOpacity: 1,
strokeWidth: 3,
fillColor: "#00AAFF",
fillOpacity: 1,
pointRadius: 8,
pointerEvents: "visiblePainted"
var templateB = {
strokeColor: "#FFFF00",
strokeOpacity: 1,
strokeWidth: 3,
fillColor: "#FFFF00",
fillOpacity: 0.25,
pointRadius: 5,
var styleMap = new OpenLayers.StyleMap({ "default" : new
OpenLayers.Style(template, {context:context}),
"select" : new
OpenLayers.Style(templateB, {context:context})
return(styleMap);
var styleLine = set_styleLine();
Or you add an attribute for the color to your route features. Then you
doesn't need the context.
Instead retrieve the color by
strokeColor: "${yourAttributeForColor}",
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Maxime
Phaneuf
Gesendet: Donnerstag, 27. Oktober 2011 21:59
An: users at openlayers.org
Betreff: [OpenLayers-Users] Change vector style dynamically
I'm developping a map where the baselayer is Google and the overlay layers
are GeoJSON I build server side.
var busRoutes = new OpenLayers.Layer.Vector("routes", {
visibility: true,
style: styleLine,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: GlobalParams.MakeUrl("mapHandler.ashx"),
format: new OpenLayers.Format.GeoJSON(),
params: { 'routes': 'all', 'action':'route' }
This works as expected. I can see my layer no problem, with the style being:
var styleLine = new OpenLayers.Style({ 'strokeColor': '#000000'});
var styleLineSelect = new OpenLayers.Style({ 'strokeColor': '#FF0505'
var styleLineTemp = new OpenLayers.Style({'strokeColor':'#ffffff'});
var smLine = new
OpenLayers.StyleMap({'default':styleLine,'select':styleLineSelect,
'temporary':styleLineTemp});
This busRoute layer shows every bus routes. Sometimes, a user will only need
to see one route instead of all. So, I built a custom layer changer where
I'm refreshing this layer with this code:
map.getLayersByName('routes')[0].refresh({ force: true, params: { 'routes':
routeNumberJSON, 'action':'route'} });
This also works as expected. I can see the specific route on the map.
The problem is that I cannot change the style (stroke color) for this
particular route. I tried setting a new style and stylemap for the layer,
and a new style for the new features. Nothing seems to work. It always keeps
the #000000 (black) stroke color. I really need to be able to change style
dynamically when I refresh the layer. I know my new style and style are
valid.
Is it possible to change style dynamically in OpenLayers?
Thanks,
Maxime
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Change-vector-style-dynamically-tp693
7851p6937851.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
