[OpenLayers-Users] How to access polygons or lines as WKT after
drawing them?
Pierre Knobel
knobel.pierre at gmail.com
Sun Oct 30 05:43:58 EDT 2011
I'm trying to write a program starting from this example:
http://openlayers.org/dev/examples/draw-feature.html
The user should be able to draw any number of polygons and lines, and
then when hitting a button on the webpage the javascript code would do
something with them. The problem is that I can't figure out how to
access these geometries.
Basically, what I have is a vector layer defined by:
drawLayer = new OpenLayers.Layer.Vector("blabla")
>From what I understand from
http://dev.openlayers.org/docs/files/OpenLayers/Layer/Vector-js.html,
http://dev.openlayers.org/docs/files/OpenLayers/Feature/Vector-js.html
and http://dev.openlayers.org/docs/files/OpenLayers/Geometry-js.html,
I should be able to retrieve the WKT of the geometries drawn by the
user the following way:
drawLayer.features[i].geometry.toString(); //i would be an
integer lower than the number of geometries on my layer
The problem is that it doesn't work, and javascript doesn't make
debugging very easy. I tried to run the following function:
function getDrawings() {
var feats = drawLayer.features;
alert(typeof feats);
alert(feats);
var spam = 0;
for(var f in feats) {
alert(typeof f);
alert(f);
spam = spam + 1;
document.getElementById("drawing_list").innerHTML = String(spam);
The counter 'spam' returns the correct number of geometries (let's say
4 for this example), when I print 'feats' I get '[object
Object],[object Object],[object Object],[object Object]', but 'typeof
f' prints a string which ends up being an incrementing number (0, 1,
2, 3) when I would expect to get a geometry object.
What am I doing wrong?
Thanks,
Pierre
