[OpenLayers-Users] OSM (OpenStreetMap) layer and controlled zoom
levels
del cadarn
del_cadarn at hotmail.com
Fri Sep 2 04:07:46 EDT 2011
Hello,
I know this is an issue that was raised a few years ago - I noticed a few posts in 2007 - but I wonder if there is now solutions that I am not aware of.
I'm trying to limit extent and zoom levels of a map including Bing and OSM basemaps. I succeed to get to do what I want for the Bing side of things but I keep getting errors with the OSM layer... either I can't get it to show up at all or it won't restrict the extent and the zooms.
here is the relevant portion of code (I'll also put below a few variants I tried for the OSM layer)
map = new OpenLayers.Map('map_element', {
maxExtent: new OpenLayers.Bounds(
-504904.79024762,
7109446.218042,
-138007.0545445,
7476343.9537452),
units: 'm',
projection: new OpenLayers.Projection('EPSG:900913'),
maxResolution: 611.496226171875,
numZoomLevels: 10
// Basemaps
//Bing
var ve_road = new OpenLayers.Layer.VirtualEarth(
'Bing Road',
{sphericalMercator:true}
var ve_aerial = new OpenLayers.Layer.VirtualEarth(
'Bing Aerial',
{type: VEMapStyle.Aerial,
//OpenStreetMap
var osm_layer = new OpenLayers.Layer.OSM(
'OpenStreetMap Layer',
{sphericalMercator:true,
numZoomLevels: 10}
now for the osm_layer I have also tried (which doesn't work either)
numZoomLevels: 10}
and (which works but doesn't limit the zooms)
I know I'm doing something wrong somewhere and there are faults in my code... Could anyone help me?
Thank you,
Delphine
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110902/a51d7508/attachment.html
