[OpenLayers-Users] How do you handle large amounts of data?
David Fawcett
david.fawcett at gmail.com
Tue Sep 6 15:15:07 EDT 2011
If you are interested in using MapServer, it now supports clustering
of points.
http://mapserver.org/mapfile/cluster.html
David.
On Tue, Sep 6, 2011 at 8:26 AM, Michael <mdm at yachtpc.com> wrote:
> The thing is that 20,000 points is more points than anyone can reasonably
> perceive on the screen to get any useful information. You are on the right
> track to consider clustering.
> My application (tracking 70 boats across the Pacific) gives me a raw data
> set of about 15,000 points each with lat, lon, time, and boat id. That's a
> lot of data to process and to upload.
> What I am doing instead is pre-thinning the data using the Douglas-Peuker
> algorithm on the server side, which nicely reduces the data to any level of
> detail you care to specify. I got about a 90% reduction in point count with
> no real loss of information on tracks.
> If your data is not lines, but discrete points, then I am less versed.
> Yeah, clustering sounds good. You may also want to use the BBOX strategy to
> only fetch the points that are relevant to your map.
> I can post the douglas-peuker code somewhere if that would be of value.
> Michael
> On 9/6/2011 6:15 AM, Tito, Joseph wrote:
> I’m trying to expand one of my current application to handle larger
> amounts of data. Right now the application comfortably handles 2000-3000
> points at a time, but I'd like to expand its capabilities to handle at LEAST
> 20,000 points. More would be nice, but the minimum requirement is 20,000.
> Displaying these 20,000 points as X number of ‘clusters’ is totally
> acceptable, as long as it gives a good visual representation of the full
> data set.
> One thing I need to take into consideration is that I have multiple data
> types represented as their own layers, and each user has the ability to turn
> on/off layers based on their personal preferences.
> My question to everyone is, how have others solved this problem? I have a
> couple server side ideas to "pre-cluster" data in mind, but I want to see
> how others have tackled this problem before I attack it. If anyone has links
> to other relevant posts or websites, please share!
> Thank you
> Joe Tito
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
