AW: [OpenLayers-Users] OSM and WMS problem using correct maxExtent,
maxResolution and projection
Arnd Wippermann
arnd.wippermann at web.de
Thu Sep 8 14:24:54 EDT 2011
Don't restrict the map options, but zoom to a defined extent with
map.zoomToExtent(extentGermany);
function init(){
var extentGermany = new
OpenLayers.Bounds(133400,5905800,2493900,7407700);
var options = {
controls:[], //create map without controls -> add them later
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
numZoomLevels: 18,
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508,
20037508.34)
map = new OpenLayers.Map('map', options);
osm= new OpenLayers.Layer.OSM("Basis Open Street Map");
var flaglayer = new OpenLayers.Layer.WMS("basic:gis_elemente",
"http://geoserver.domain.com:80/geoserver/basic/wms",
{ layers: 'basic:gis_elemente',
transparent:true
map.addLayers([osm,flaglayer]);
map.addControl(new OpenLayers.Control.Navigation());
map.addControl(new OpenLayers.Control.MousePosition());
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.PanZoomBar());
Delete the projection key in the WMS parameters. Projection is not a WMS
parameter.
The WMS projection parameter "SRS" will be set by OpenLayers with the
map.projection.
Viele Grüße,
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Gabriele
Seitz
Gesendet: Donnerstag, 8. September 2011 18:03
An: users at openlayers.org
Betreff: [OpenLayers-Users] OSM and WMS problem using correct maxExtent,
i cannot get the features of my WMS onto the OSM-Map. THe nearest i can get
is this approach with the features laying in "Gulf of Guinea".
I need them in Germany, though.
Geoserver Layer-preview of WMS in firebug-DOM-tab shows:
- maxExtent=left-bottom=(6.798,48.141) right-top=(13.705,54.325),
- maxResolution=0.02698046875,
- projection=EPSG:900913
OSM layer-Properties in Firebug -DOM information show:
- maxExtent=left-bottom=(-20037508.3392,-20037508.3392)
right-top=(20037508.3392,20037508.3392),
- maxResolution =156543.0339,
Code:
function init(){
var extent=new OpenLayers.Bounds(6,48,13,55);
var options = {
//controls: [],
maxExtent: extent
,maxRsolution: 0.02698046875
,projection:"EPSG:900913"
var osm= new OpenLayers.Layer.OSM("Basis Open Street Map");
transparent:true,
projection: "EPSG:900913"
map.addLayers([ osm,flaglayer]);
map.addControl(
{'div':OpenLayers.Util.getElement('layerswitcher')}
map.zoomToExtent(extent);
How do I fit maxExtent and maxResolution to show OSM and WMS correctly?
Thanks for answering.
Gabriele
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/OSM-and-WMS-problem-using-correct-max
Extent-maxResolution-and-projection-tp6772420p6772420.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
