[OpenLayers-Users] Re: Can't get clustering work
chemiker stefa.1 at web.de
Sat Sep 10 12:08:35 EDT 2011
Hi Denis, thanks for your answer. addBuilding is a custom function that creates a vector on the vector layer with a special icon. I already use vectors instead of markers, apologies for my unclear description. I do have a vector layer and place different vectors of OL.Features.Vector on it. But I can't get the clustering work so far. The only difference between your code and mine is that you add 'autoactivate: true' to your Cluster constructor, I don't know if this is mandatory for the clustering to work, I will test it on Monday. Any other comments on that? I really appreciate your fast and competent answer! Regards Stefan Von: "dr [via OSGeo.org]" <ml-node+s1803224n6778619h80 at n2.nabble.com> Gesendet: Sep 10, 2011 2:16:52 PM An: chemiker <stefa.1 at web.de> Betreff: Re: Can't get clustering work Hi! What is addBuilding function? I'm not sure about cluster strategy may be used with markers. I'm prefer to use features, because markers are deprecated: <html><body>
  <div id="mapdiv"></div>
  <script src="http://openlayers.org/dev/OpenLayers.js"></script>
  <script>
    map = new OpenLayers.Map("mapdiv");
    map.addLayer(new OpenLayers.Layer('', {isBaseLayer: true, maxExtent: new OpenLayers.Bounds(-200,-200,200,200)}));
    var buildingLayer= new OpenLayers.Layer.Vector("Buildings", {maxExtent: new OpenLayers.Bounds(-200,-200,200,200),
        strategies: [new OpenLayers.Strategy.Cluster({autoActivate: true, distance: 100})]
    map.addLayer(buildingLayer);
    buildingLayer.addFeatures([new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(-50.126,36.755)),
    new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(-100.196,43.215)),
    new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(-150.556,56.615)),
    new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(-170.423,35.510))]);
    map.zoomToMaxExtent();
  </script>
</body></html> Denis Rykov NextGIS http://www.nextgis.org/ If you reply to this email, your message will be added to the discussion below: http://osgeo-org.1803224.n2.nabble.com/Can-t-get-clustering-work-tp6777723p6778619.html To unsubscribe from Can't get clustering work, click here .    Schon gehört? WEB.DE hat einen genialen Phishing-Filter in die    Toolbar eingebaut! http://produkte.web.de/go/toolbar
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-get-clustering-work-tp6777723p6779018.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110910/043801a0/attachment.html
