[OpenLayers-Users] Re: Version 2.11 - What happened to the NavToolbar?
magerlin MAP at ramboll.dk
Tue Sep 13 10:38:45 EDT 2011
Tanks for pointing that out - I had a modified css file based on version 2.10
involved.
Changing it to be based on the version 2.11 default Style.css changend that
problem. But also showed some new:
It should be possible to select festures (buildings when zoomed in) to get a
popup, but after having used one of the buttons on the NavToolbar it is no
longer possible to selct a feature? In version 2.10 I could select a feature
if I had clicked the panning hand first.
One of my modifications in the css was to move the NavToolbar up just below
the other controls, but that I can't get to happen now. Nomatter how I
modify the css it stays on the same place (or totally disappears!) I know
this is purely CSS....
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Version-2-11-What-happened-to-the-NavToolbar-tp6786921p6787765.html
