[OpenLayers-Users] olhttp: Integration of Django and OpenLayers
christopher.schmidt at nokia.com
Thu Sep 15 11:18:21 EDT 2011
Over the last couple weeks, I've been doing a little bit of work on a Django
application designed to show how to use OpenLayers for editing in an application.
The code is available from:
https://github.com/crschmidt/olhttp/
The code demonstrates a couple things:
1. How to create a simple server-side GeoDjango application which supports simple
output as GeoJSON, giving explicit URLs to data objects and using GeoJSON as input
output. (This is essentially FeatureServer, ported to GeoDjango as a backend;
it uses the core components of FeatureServer for Django feature reading and GeoJSON
writing.)
2. It implements an easy-to-customize editing interface for OpenLayers, which supports
simple entry of attributes, and uses Protocol.HTTP, Protocol.Save, and OpenLayers
Layer/Protocol/Format support to do all of the heavy lifting.
I've deployed a branch of this code set up specifically to target tablet/mobile-based
editing at http://olhttp.djangozoom.com/ out of the 'djangozoom' branch of that tree.
The key OpenLayers component of this is:
https://github.com/crschmidt/olhttp/blob/18cd2f42da28bede88e7e407b60a0e5851ab59f1/main/static/js/olhttp.js
This code is designed to be reusable -- it shouldn't generally need to be modified
a ton for a given application. (In order to take the code I implemented for olhttp
on a desktop, and modify it for the tablet, the only thing I ended up changing
was the zoomToExtent() line.)
So, if you have ever wanted to implement *any* of:
- Display of multiple features from a Django-based backend
- Drawing of features in a map, with automatic saving of features to a backend
- Simple editing of attributes using HTML forms
I would recommend checking out olhttp.
(Pull requests welcome.)
Christopher Schmidt
Nokia
