[OpenLayers-Users] Proxy.php
jrom jerome.gasperi at gmail.com
Tue Sep 20 09:37:39 EDT 2011
Hi Gabriele,
Using PHP curl you should try something like this :
<?php
        $url = $_REQUEST["url"];
        $curl = initCurl($url);
        curl_setopt($curl, CURLOPT_URL, $url);
        curl_setopt($curl, CURLOPT_RETURNTRANSFER, TRUE);
        curl_setopt($curl, CURLOPT_HTTPHEADER, array(
                'POST HTTP/1.0',
                'Content-type: text/xml;charset="UTF-8"',
                'Accept: text/xml',
                'Cache-Control: no-cache',
                'Pragma: no-cache'
        curl_setopt($curl, CURLOPT_POSTFIELDS, $HTTP_RAW_POST_DATA);
        curl_setopt($curl, CURLOPT_POST, TRUE);
        $theData = curl_exec($curl);
        curl_close($curl);
        echo $theData;
This is very untested code :) However modifying it to check if 'url'
is correctly set and to restrict access only to allowed host should be
easy
Regards
Jerome
http://jrom.info
On Tue, Sep 20, 2011 at 2:59 PM, Gabriele Seitz <ml-seitz at web.de> wrote:
> Hi everybody,
> I still haven't solved my problems with WFS and Proxy. There seems to be a
> problem with the proxy.php I used for testing. It seems to be written in
> PHP4 but I need it in PHP5 and it doesn't support POST.
> Is there anybody, who can provide me with a proxy.php to send my
> WFS-Requests to Geoserver (php5, acceppting POST, restricted to allowed
> hosts would be perfect)?
> Everything else seems to be okay.
> Thanks a lot.
> Gabriele
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Proxy-php-tp6812192p6812192.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
