[OpenLayers-Users] drawing a geojson layer
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Fri Sep 23 16:21:11 EDT 2011
On Sep 23, 2011, at 4:15 PM, ext Puneet Kishor wrote:
> On Sep 23, 2011, at 3:05 PM, <christopher.schmidt at nokia.com> wrote:
>> Are you using OSM? Did you reproject your coordinates anywhere?
> No, I am using Google Maps base layer. My data are in lat/lng, so I believe this s a re-projection issue.
> I redefined my map like so
>            map = new OpenLayers.Map("map", {
>                controls: [
>                    new OpenLayers.Control.LayerSwitcher(),
>                    new OpenLayers.Control.MousePosition({div:document.getElementById("coords")})
>                projection: new OpenLayers.Projection("EPSG:900913"),
>                displayProjection: new OpenLayers.Projection("EPSG:4326")
> and then
>            var vector_layer = new OpenLayers.Layer.Vector(
>                "vector layer",
>                {projection: new OpenLayers.Projection("EPSG:4326")}
>            map.addLayer(vector_layer);
> and then
>           var geojson_format = new OpenLayers.Format.GeoJSON();
>           vector_layer.addFeatures(geojson_format.read(featurecollection));
> I am assuming that is not the right way, because that is not working. Do I have to transform every point one by one?
http://docs.openlayers.org/library/spherical_mercator.html#serializing-projected-data
(The same config options on the format apply to both serializing
and deserializing.)
-- Chris
>> -- Chris
>> On Sep 23, 2011, at 3:07 PM, ext Puneet Kishor wrote:
>>> I have a fairly straightforward code like so, with the JSON data coming out of Pg. I am using OL 2.11
>>>  var data = {
>>>    "type" : "FeatureCollection"
>>>    "features" : [
>>>          "geometry" : {
>>>             "coordinates" : [[[x1, y1], [x2, y2], [x3, y3]]],
>>>             "type" : "MultiLineString"
>>>          "type" : "Feature",
>>>          "properties" : {"code" : 101, "desc" : "blah" }
>>>          "geometry" : {
>>>          "type" : "Feature",
>>>          "properties" : {"code" : 102, "desc" : "blah" }
>>>          "geometry" : {
>>>          "type" : "Feature",
>>>          "properties" : {"code" : 103, "desc" : "blah" }
>>>  var lyr = new OpenLayers.Layer.Vector("layer name");
>>>  PK.vars.map.addLayer(lyr);
>>>  trenches.addFeatures(geojson_format.read(data));
>>> Yet, no errors and no features drawn on the map. What am I doing wrong?
>>> Puneet._______________________________________________
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
