[OpenLayers-Users] attribute based styles
Mr. Puneet Kishor
punk.kish at gmail.com
Sat Sep 24 08:31:45 EDT 2011
On Sep 23, 2011, at 5:25 PM, <christopher.schmidt at nokia.com> <christopher.schmidt at nokia.com> wrote:
> On Sep 23, 2011, at 6:15 PM, ext Puneet Kishor wrote:
>> and the layer definition is
>> var lyr = new OpenLayers.Layer.Vector(
>> "a layer", {
>> style: {
>> "strokeWidth": 1,
>> "strokeColor": "#ff0000",
>> "fillColor": "#ff0000",
>> "fillOpacity": "${opacity}",
>> "pointRadius": "${radius}"
>> I was expecting the points to be rendered with the radius and opacity values for each feature. But not so. What am I doing wrong?
> s/style:/styleMap: new OpenLayers.StyleMap({'strokWidth':, etc.})/
Thanks, that works. Perhaps the following should be corrected at [http://docs.openlayers.org/library/feature_styling.html]
> The most common way of accessing attributes of the feature when creating a style is through the attribute replacement syntax. By using style values like ${varname} in your style, OpenLayers can replace these strings with attributes of your feature. For example, if you had a GeoJSON file where each feature had a thumbnail property describing an image to use, you might use something like:
> var s = new OpenLayers.Style({
> 'pointRadius': 10,
> 'externalGraphic': '${thumbnail}'
